Schellsbeer
Jan 11, 2025Aspirant
Outdoor WiFi extender
Hi, I was just curious if anyone knows if netgear makes a long range wifi extender. Due to a lot of criminal activities in town and want to protect my operation from unwanted traffic, I would like to ...
- Jan 15, 2025Alright, well thank you all for your help and advice.
Schellsbeer
Jan 13, 2025Aspirant
Thanks for breaking that down and explaining it. If I’m comprehending this all correctly. For my set up to work I’m not entirely sure the one signal from the point to point would work as I have four barns three are placed in the shape of a u and the fourth is to the north of the three of them and my house is to the left of the of the barns. So my intention is to place one camera on the east bin of the north and south barn to point at the entry points of the driveway. I’m not sure a PoE would work with a master and slave bridge as I’m not sure if I would get interference so I was looking at a Wi-Fi camera specifically the dahua n41bl13-w plug in Wi-Fi camera because my thinking is if the bridges extend my wifi then this camera could pick up the wifi without having to buy two slave bridges. Or am missing something? My other thought was if I have to have two slaves to run PoE for camera is it possible that point to point would work two with two slaves or do I have to get two master and two slaves?
JWS9518
Jan 13, 2025Luminary
In my setup, I have one receiving antenna where the NVR is located and in the separate locations, I have another sending antenna, with a total of 6. These antennas ideally work with a line of sight and in the case where I have no direct line of sight to one of the locations, I have it setup with an antenna that sends a signal to another location that forwards that to the receiving end. Each location is going to need some type of way to send the camera signal.
Someone else may have other ideas to do that, but this is how the setup I have here, which was professionally installed, with the exception of the 2 hard wired cameras that I did myself. I did not want to climb a ladder. 😬
