Orbi_Guelph
Jul 23, 2023Aspirant
Outdoor Extender Options
I bought Netgear Orbi RBK853-100CNS Tri-band Mesh WiFi 6 System from Costco. Love it. I am not looking to extend wifi coverage outdoors. Since the RBS50Y looks like it is discontinued, what other options would you recommend?
Also if I just buy a couple of extra satellites any recommendations of what models and where I can get them. I can only find them with a router which I do not need. I live in Canada?
I see posts from 2020 suggesting there is no option as yet. I am hoping netgear has a new option now.
Thanks.
The RBK853 — Orbi WiFi 6 System AX6000 consists of (1) Orbi Router (RBR850) + (2) Orbi Satellites (RBS850).
Consult the Which Orbi routers and satellites are compatible? list.
- Orbi_GuelphAspirantThanks for link. It is not listed.
