Schellsbeer
Jan 11, 2025Aspirant
Outdoor WiFi extender
Hi, I was just curious if anyone knows if netgear makes a long range wifi extender. Due to a lot of criminal activities in town and want to protect my operation from unwanted traffic, I would like to ...
- Jan 15, 2025Alright, well thank you all for your help and advice.
danielglimmer1
Oct 08, 2025Aspirant
For a distance of 700–900 feet with obstacles like barns in the way, standard Netgear Wi-Fi extenders likely won’t provide reliable coverage, as most consumer-grade extenders are designed for 100–150 feet indoors or slightly more outdoors with a clear line of sight. A better solution would be to use point-to-point Wi-Fi bridges, such as Ubiquiti NanoStation or TP-Link CPE series, which are designed for long-range outdoor links and can handle some obstructions. High-gain outdoor antennas can help, but their range is still limited compared to dedicated bridges, and while outdoor mesh units might extend coverage, 700–900 feet with buildings in the way is beyond typical consumer mesh capabilities.
