PaddyVu
Apr 06, 2019Tutor
Port forwarding wont work
I cant port forwarding to 8193,it doesnt work at all,i read some web that said services must run on that port but i dont know how to do that. I'm try to play MHW on remotr using mobile data and PC us...
- Apr 08, 2019
Hi @PaddyVu,
Since this community is dedicated for NETGEAR Business Wireless Access Points, it would be best that you either contact the G-97RG3 Technical Support or if ever your Internet Service Provider installed the G-97RG3 router for you, then you can contact them for technical assistance.
Let me inform you that there is a YouTube video about Port Forwarding on the G-97RG3 router. However, it is on Vietnamese language (if ever I'm not mistaken). You may want to check it on YouTube.
DaneA
NETGEAR Community Team
schumaku
Apr 06, 2019Guru - Experienced User
Router model, firmware version, ... what ISP, what Internet CPE/modem/router in front (probably duouble NAT)?
Your ISP does assign public routeable IPv4 addresses to your Internet connection to _that_ router?
Afraid, in-line image moderation does take much to long here, so we won't see the images before next week or so.
PaddyVu
Apr 06, 2019Tutor
I dont know anything about my network,how can i check it? Can you teamview and help me? :(
