PaddyVu
Apr 06, 2019Tutor
Port forwarding wont work
I cant port forwarding to 8193,it doesnt work at all,i read some web that said services must run on that port but i dont know how to do that. I'm try to play MHW on remotr using mobile data and PC us...
- Apr 08, 2019
Hi @PaddyVu,
Since this community is dedicated for NETGEAR Business Wireless Access Points, it would be best that you either contact the G-97RG3 Technical Support or if ever your Internet Service Provider installed the G-97RG3 router for you, then you can contact them for technical assistance.
Let me inform you that there is a YouTube video about Port Forwarding on the G-97RG3 router. However, it is on Vietnamese language (if ever I'm not mistaken). You may want to check it on YouTube.
DaneA
NETGEAR Community Team
schumaku
Apr 06, 2019Guru - Experienced User
Router model, firmware version, ... what ISP, what Internet CPE/modem/router in front (probably duouble NAT)?
Your ISP does assign public routeable IPv4 addresses to your Internet connection to _that_ router?
Afraid, in-line image moderation does take much to long here, so we won't see the images before next week or so.
PaddyVu
Apr 06, 2019Tutor
I think my router model is
| Model Name | G-97RG3 |
| Software Version | R4.2.43.078g |
| Hardware Version | C30-401 |
My isp : FPTDYNAMICIP also known as 'FPT Telecom Company' and 'The Corporation for Financing & Promoting Technology' ( i check this from whoismyisp org)
"what Internet CPE/modem/router in front (probably duouble NAT)? " what is this? how can i check it?
"Your ISP does assign public routeable IPv4 addresses to your Internet connection to _that_ router?" i dont know,how can i check it?
- DaneAApr 08, 2019NETGEAR Employee Retired
Hi @PaddyVu,
DaneA
- PaddyVuApr 08, 2019Tutor
DaneA wrote:
Hi PaddyVu,
Let me share that there is a YouTube video about Port Forwarding on the G-97RG3 router. However, it is on Vietnamese language (if ever I'm not mistaken). You may want to check it on YouTube.
DaneA
Yes i'm vietnamese,can you provide me the link? thanks
Hi @PaddyVu,
Here are the links below:
https://lapdatcameraip.vn/ho-tro/mo-port-modem-fpt-g97rg3.htm -
https://www.youtube.com/watch?v=Lhm3TLJJUjg - it is not exactly the G-97RG3 model but it is similar to it.
DaneA
DaneA wrote:
Hi @PaddyVu,
DaneA
DaneA wrote:
Hi @PaddyVu,
DaneA
Hi,i'm extremely appreciate you, all my port is opened now when i contact them,they block that port so i need to contact them to open it !!!! TKS <3 <3 <3 now i can play PC games with my phone everywhere
