PaddyVu
Apr 06, 2019Tutor
Port forwarding wont work
I cant port forwarding to 8193,it doesnt work at all,i read some web that said services must run on that port but i dont know how to do that. I'm try to play MHW on remotr using mobile data and PC us...
- Apr 08, 2019
Hi @PaddyVu,
Since this community is dedicated for NETGEAR Business Wireless Access Points, it would be best that you either contact the G-97RG3 Technical Support or if ever your Internet Service Provider installed the G-97RG3 router for you, then you can contact them for technical assistance.
Let me inform you that there is a YouTube video about Port Forwarding on the G-97RG3 router. However, it is on Vietnamese language (if ever I'm not mistaken). You may want to check it on YouTube.
DaneA
NETGEAR Community Team
DaneA
Apr 08, 2019NETGEAR Employee Retired
Hi @PaddyVu,
DaneA
PaddyVu
Apr 08, 2019Tutor
DaneA wrote:
Hi PaddyVu,
Let me share that there is a YouTube video about Port Forwarding on the G-97RG3 router. However, it is on Vietnamese language (if ever I'm not mistaken). You may want to check it on YouTube.
DaneA
Yes i'm vietnamese,can you provide me the link? thanks
- DaneAApr 08, 2019NETGEAR Employee Retired
Hi @PaddyVu,
Here are the links below:
https://lapdatcameraip.vn/ho-tro/mo-port-modem-fpt-g97rg3.htm -
https://www.youtube.com/watch?v=Lhm3TLJJUjg - it is not exactly the G-97RG3 model but it is similar to it.
DaneA
