Murrayfield
Mar 09, 2017Tutor
Pro Safe Wireless Access Point WN370
I have purchased four of these Wireless Access Points without realising that I require to purchase a controller to manage these thinking they were stand alone devices. What is the most inexpensive c...
- Mar 15, 2017
Hi,
Just for the clarify the WN370 can be managed by WC7600, WC9500, WC7600v2, WC7500 controllers.
DaneA
Mar 14, 2017NETGEAR Employee Retired
Hi Murrayfield,
Welcome to the community! :)
I'm afraid to inform you that the WN730 can only be managed by the WC7600 wireless controller. Since you need a standalone access point, I suggest the WAC510 access point. Kindly check its specification and comparison with other NETGEAR access points on the data sheet here.
DaneA
NETGEAR Community Team
Murrayfield
Mar 15, 2017Tutor
Hi DaneA
Thanks for the info. I did a bit more research in between posting the question and receiving your reply and I have a query. One of the documents I searched on came up with the following (page 2) https://www.netgear.com/images/pdf/WC7500_DS_30Mar16.pdf which seems to show support for the WN370 by the WC7500. Well I hope so 'cos I have bought one ;-)
Cheers
Ian
