Murrayfield
Mar 09, 2017Tutor
Pro Safe Wireless Access Point WN370
I have purchased four of these Wireless Access Points without realising that I require to purchase a controller to manage these thinking they were stand alone devices. What is the most inexpensive c...
- Mar 15, 2017
Hi,
Just for the clarify the WN370 can be managed by WC7600, WC9500, WC7600v2, WC7500 controllers.
Murrayfield
Mar 17, 2017Tutor
Hi
I can categorically say that the wc7500 will manage the wn370 I managed to get four working today. The first two were easy but the second two were a problem. In the end I rebooted the wc7500 then plugged in each AP individually factory reset the AP found it on the controller then edited the AP and the WC to fit into my network op address scheme. Worked a treat
