Murrayfield
Mar 09, 2017Tutor
Pro Safe Wireless Access Point WN370
I have purchased four of these Wireless Access Points without realising that I require to purchase a controller to manage these thinking they were stand alone devices. What is the most inexpensive c...
- Mar 15, 2017
Hi,
Just for the clarify the WN370 can be managed by WC7600, WC9500, WC7600v2, WC7500 controllers.
Murrayfield
Mar 18, 2017Tutor
Hi Christophe
WC7500. 6.0.1.0
WN370. 6.0.1.0_3875
Regards
Ian
WC7500. 6.0.1.0
WN370. 6.0.1.0_3875
Regards
Ian
mmosegui
Mar 27, 2017Aspirant
I just have bought THREE wn370 to realize that I need to buy also a @#!? additional "machine" to have them configured. Is there any other mean to configure them? telnet? https? ftp?. When they first are powered I presume they send a DHCP discover and "WireSharking" the communications (yes, I have a primitive HUB not SWITCH that can propagate packets) so I could know their IPs. No chance?
- LaxmankumarGMar 27, 2017NETGEAR Expert
Hi,
WN370 can only be managed and configured by the following WLAN controllers.
WC7500, WC7600, WC7600v2, WC9500. You have to buy one of these controllers to make WN370 work, and there is no other option to configure it.
- mmoseguiMar 27, 2017Aspirant
So no chance with the "http://192.168.0.160" that is used to obtain the logs when a WC cannot discover the unit? :
The WC7600 Cannot Discover or Manage the AccessPointIf the WC7600 cannot discover or manage the access point, you can log in to theaccess point to troubleshoot and download the system log. NETGEAR support willuse the system log to help diagnose any problems with the access point.Note:The WN370 has DHCP enabled by default and receives an IP address if youhave a DHCP server in your network. If you have a DHCP server in your network,use the address assigned to the WN370 to log in to the access point.To log in to the access point and download the system log:1.Configure a computer with the following IP options:•IP address. 192.168.0.22•Subnet mask. 255.255.255.0•Default gateway. 192.168.0.12.Enter http://192.168.0.160 or your access point’s assigned IP address into abrowser.3.Log in to the access point using the following default credentials:•ID. admin•Password. password
