Latchman
Dec 30, 2024Aspirant
Qty of (23) WAX625 on GSM4352 with variances on speed tests
We have a Qty of (23) WAX625 installed throughout our space. All are running firmware 10.8.9.7 and selected as manage on the cloud. All of these WAX625 run back to the GSM4532 and are powered POE. Th...
Pramendra
Dec 31, 2024NETGEAR Expert
Hi Latchman
I would suggest relying more on the speed test results run on the client connected to the AP, as this defines the end user experience.
To get the best results, ensure clients are connected on 5GHz and have a good signal strength from the AP. Also, check if your deployment has no channel interference from neighboring APs. If possible, please change the channel width to 80MHz (without channel overlap).
Thanks!
Pramendra Singh
NETGEAR NFB Wireless
- LatchmanDec 31, 2024Aspirant
We will try these steps.
