hoser7632
Jan 28, 2026Follower
Help understanding the "Set the 802.1Q VLAN and management VLAN" WBE750
On my router I have a X550 interface tagged with a vlan ID of "4" which attaches to my switch port as a "trunk port with a vlan id of "4"" on the switch I have an "access Port with a vlan id of "4" t...
schumaku
Jan 31, 2026Guru - Experienced User
hoser7632 wrote:"Set the 802.1Q VLAN and management VLAN"
You can operate the management VLAN and each SSID on dedicated (tagged!) VLAN(s) - of course these VLANs must exist, be have to be workable, need dedicated IP subnetwork(s), and ideally each a DHCP service active. An access port alone is not sufficient, as this makes untagged traffic for one VLAN only.
