BIG9MM
Jan 15, 2025Apprentice
HELP! WAX630 QoS Settings is greyed out.
Firmware V10.8.11.4. I don't know if it's the firmware or if I'm doing something incorrect but it's not accessible as it doesn't give me the option to disable "WMM Powersave" in the WAX630 web interf...
ErwinL
Jan 23, 2025NETGEAR Moderator
Hello BIG9MM
And welcome to the NETGEAR Community! 🙂
It's good that you have openned a ticket about your issue, so that engineering can take a look at it if needed to be escalated. Have you done a factory reset on the device yet?
Have a lovely day,
Erwin
Netgear Team
BIG9MM
Jan 23, 2025Apprentice
The technical support team over the phone asked the same question you did.
I have a question for you. Have you done a factory reset on your work WAX630 and logged in to see if your functionality is active with the same software I provided above?
Do you guys have access to the same equipment as the WAX630?
