BIG9MM
Jan 15, 2025Apprentice
HELP! WAX630 QoS Settings is greyed out.
Firmware V10.8.11.4. I don't know if it's the firmware or if I'm doing something incorrect but it's not accessible as it doesn't give me the option to disable "WMM Powersave" in the WAX630 web interf...
ErwinL
Jan 28, 2025NETGEAR Moderator
Hello BIG9MM
Unfortunately, we do not have the same level of access. However, resetting to factory defaults is a basic troubleshooting step that is often overlooked. If you wish, you may provide an update on your case with our support team?
Have a lovely day,
Erwin
Netgear Team
BIG9MM
Jan 28, 2025Apprentice
11b 11bg 11ng 11ax
The workaround is to take it off 11ax and put it on 11ng until they have a firmware update. :]
