Tom2112's avatar
Tom2112
How to disable WPA3 and enable WPA2 only on WAX630E access point?
I have a Netgear WAX630E access point running firmware v10.8.11.4 that I do not have connected to cloud management. The local management interface only has four options for wireless authentication: n...
  • hnagaraju's avatar
    Jan 15, 2025
    Create the SSID for only 2.4Ghz and 5Ghz Radios.
    Only WPA3 is allowed on 6Ghz as per Wi-Fi standards.
    If 2.4Ghz/5Ghz/6Ghz is enabled one the SSID,  then WPA2/WPA3 is the minimum that is allowed
    One common way to achieve this is to create two SSIDs linked to the same wired network.
    One WPA3_only SSID is for newer Wi-Fi clients, and another WAP2_only SSID is for legacy Wi-Fi clients.
ProSupport for Business
