Batman-15
Aug 29, 2022Tutor
Netgear WAX 620 Access Point
Good evening: I just installed on my Netgear WAX 620 Access point. Is there a way for me to extend the access points signal using my RAXE 300 router? Any and Help suggestions will be greatly apprec...
michaelkenward
Aug 29, 2022Guru - Experienced User
Batman-15 wrote:
Thank you for your reply. Perhaps a little more detail will help you understand what I am trying to accomplish. I have purchased a firewalla purple router. I have connected my WAN line to its WAN port. I have connected the Firewallas LAN port to a Netgear GS308T managed switch. I have connected the Netgear WAX 620 AP to port 1 of the switch. All I'm asking is can I use the RAXE 300 router to extend the access points range and if so what are the steps I need to execute to accomplish this.
Thanks again for your patience and help!
I thought we were talking about the WAX620.
There is nothing to stop you from using the RAXE300 as an access point, wired back to your switch or to the main router.
Dig out its manual and follow the bit Set up the router as a WiFi access point. Should be dead easy.
Most routers have an AP mode.
Be warned that AP mode has its drawbacks.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
But you already have a router on your network.
I know nothing about the Purple Router, so have no idea what it will do for you.
Batman-15
Aug 29, 2022Tutor
Thank you so much for your response! I was hoping I could set it up as a wireless access point back to my wired access point without having to run an ethernet cable to it. I guess I'm out of luck.
- michaelkenwardAug 29, 2022Guru - Experienced User
That seems to be a dying feature in Netgear routers.
You could still try Powerline Ethernet as an ersatz Ethernet. Could be cheaper than buying a purpose built repeater. After all the RAXE300 won't have been cheap.
Hang on, the manual for the RAXE300 says Set up the router in bridge mode. Did you check that?
The trouble is that Netgear, and others, use "bridge mode" to mean different things, depending on the context. (It also uses the term "WDS" to describe some types of wifi repeating.)
You have nothing to lose by trying it.
The RAXE is a relatively new device, so there hasn't been much chat about it around here. This is the first time I've seen any talk of it.
