Galljc
Jun 01, 2017Aspirant
WAC730 Back To Standalone Mode Via Console
 I have a WAC730 that need to go back to standalone.  It has a centralized management type firmware on it.  I've connected to it via console cable and I connect and logon as root and use password to l...
- Jun 02, 2017
I was able so solve this.
I setup a TFTP server and copied the 3.7 firmware to my tftp directory.
Then I used a console cable to access the WAC730 independant of the network.
I tried running firmware-upgrade-tftp firmware.tar 192.168.1.29 which did copy the file and try and run the upgrade but this is where it would fail due to read only restrictions preventing the upgrade.
So I found a command on the console to simply TFTP the .tar file to the /tmp folder on the WAC730. Then once it was in place I ran another script called firmware-upgrade or something like that pointing it at the newly copied firmware.tar file
That let the WAC730 perform the firmware upgrade successfully this put it back to normal firmware where I could logon and change it to standalone.
RaghuHR
Jun 02, 2017NETGEAR Expert
Hi Galljc
Is your WAC730 managed by any Netgear wireless controller earlier? Have you tried factory reset after the tftp transfer completes?
Thanks
Raghu
Galljc
Jun 02, 2017Aspirant
Is is not but I suspect it was in a former life. I did resolve this by using the console and TFTP to copy over the firmware and run it from the busybox shell that put it back to 3.7 standalone
