mario_ed
Sep 21, 2023Guide
WAX220 initial configuration does not work
Today I bought two WAX220 (AX4200) access points and I tried to configure them. I connected two Ethernet with PoE. Network WAX220xxxxxxxx-CONFIG-ONLY came in. But when I tried to connect using the p...
schumaku
Sep 22, 2023Guru - Experienced User
mario_ed wrote:
Finally we managed to get connected through the RJ45 port with a PC, disabling DHCP and getting an IP in the same network that device default (192.168.0.xxx).
Had checked the DHCP server (router) assignment for the device before going the hard way?
Nicely, these WAX are announcing themselves by SSDP (Simple Service Discovery Protocol, by a multicast packet to 239.255.255.250 on port 1900 UDP), usually visible on Windows Explorer for example.
mario_ed wrote:
This was allowing us to access the configuration and the password written in the WAX220xxxxxxx-CONFIG-ONLY network. Surprisingly the password was completely different to the one written in the device label. It still uses two common words and 3 numbers, but it has nothing to do with the one in the label.
This is what confused me, too. Not sure if this happens by default, or if a new key is defined when re-activating.
mario_ed wrote:
It seems you have a quality problem here. Two devices with wrong password label, it is something to look at.
Not me, I'm not Netgear. This is why I made a similar description recently, intended for Netgear QA. From what I understand, the two words and the nnn is generated based on the device serial number, and should match with the config and the printed label, indeed.
DavidGo
Sep 22, 2023NETGEAR Expert
I don't recall seeing this when setting up WAX220 myself inhouse. I'll test it again as soon as possible to see if I hit this issue.
Can you please PM me with serial number, screenshot of the label with the SSID & passphrase and screenshot of the password in the web gui?
I'll raise a bug with engineering team.
Thanks
DavidGo
- mario_edSep 22, 2023Guide
Here you go. I give you the label one of the devices.
I give you the other in a separated file.
The other one:
I do not want to give you the real password because I am still using it. I would say that one starts is "bravebananaXXX". Not even close...
I am curious to know the outcome of this. Let us know the result of your investigation...
