jesusdf's avatar
jesusdf
WAX220 v1.0.3.4 + Management VLAN + Radius + AP VLAN = No connection
As the title says, I could reproduce what was told in this post:
https://community.netgear.com/t5/Business-Wireless/WAX220-WPA2-Enterprise-help-with-VLAN/td-p/2323906
But I have managed to find a way for it to work, however the workaround is not a valid solution for us.
My desired configuration is as follows:
Updated to latest firmware to date (v1.0.3.4).
Management VLAN: 20
WAX220 Management IP (DHCP): 172.16.20.10, gateway on 172.16.20.1
RADIUS server on another VLAN, IP 10.0.10.30, the firewall has rules to allow the connection.
Access Point: "MyWiFi" -> WPA2 Enterprise (or WPA3 Enterprise, same behaviour) + VLAN Isolation 30 (Users)
Expected behaviour: Wireless works and user gets connected to the VLAN 30 (Users).
Tested behaviour: No connection, not a single packet sent over the network (made many packet catpures on all the VLANs).
Workaround that I found while I was testing:
If I set the Access Point "MyWiFi" VLAN to the same id of the management VLAN (VLAN 20), the radius server receives the authentication packet and the wireless connection works, however, wireless client gets an IP on the management VLAN, instead of the desired Users VLAN (30).
Seems like there is some kind of problem with the routing table and the RADIUS authentication is not sent over the correct network interface.
  • The proposed solution is to RMA the devices for a different (newer) model, which I accepted.
    I hope that fixes it, if not, seems like OpenWRT would be the best solution for that use case.
  • ErwinL's avatar
    ErwinL
    NETGEAR Moderator
    Hello jesusdf
    And welcome to the NETGEAR Community! 🙂
    What is your switch configuration, specifically the port where the AP is connected?
    Have a lovely day,
    Erwin
    Netgear Team
    • jesusdf's avatar
      jesusdf
      Hi, All the VLANs are setup as tagged on that port, so it works as a trunk. The VLAN 1 (untagged) is not used anywhere, everything has a VLAN.
      • ErwinL's avatar
        ErwinL
        NETGEAR Moderator
        Hello jesusdf
        Looks like the port is also a member of VLAN 20. May I know which port is your DHCP server for all VLANs is connected? Is that port a member of all the VLANs on the switch? Is it coming from a router, switch or a PC? Is it tagged as well?
        Have a lovely day,
        Erwin
        Netgear Team
ProSupport for Business
