jesusdf
Sep 05, 2024Aspirant
WAX220 v1.0.3.4 + Management VLAN + Radius + AP VLAN = No connection
As the title says, I could reproduce what was told in this post: https://community.netgear.com/t5/Business-Wireless/WAX220-WPA2-Enterprise-help-with-VLAN/td-p/2323906 But I have managed to fi...
- Nov 26, 2024
The proposed solution is to RMA the devices for a different (newer) model, which I accepted.
I hope that fixes it, if not, seems like OpenWRT would be the best solution for that use case.
ErwinL
Sep 08, 2024NETGEAR Moderator
Hello jesusdf
And welcome to the NETGEAR Community! 🙂
What is your switch configuration, specifically the port where the AP is connected?
Have a lovely day,
Erwin
Netgear Team
- jesusdfSep 09, 2024Aspirant
Hi, All the VLANs are setup as tagged on that port, so it works as a trunk. The VLAN 1 (untagged) is not used anywhere, everything has a VLAN.
- ErwinLSep 09, 2024NETGEAR Moderator
Hello jesusdf
Looks like the port is also a member of VLAN 20. May I know which port is your DHCP server for all VLANs is connected? Is that port a member of all the VLANs on the switch? Is it coming from a router, switch or a PC? Is it tagged as well?
Have a lovely day,
Erwin
Netgear Team- jesusdfSep 10, 2024Aspirant
Everything is connected to a pfSense firewall and a switch. The switch configuration is fine, it's a problem with the netgear firmware.
To reproduce it:
1) Management with VLAN A.
2) Wireless with VLAN B.
3) If the access point security is WPA3 personal, the connection works as expected, the users get into VLAN B, and the web administration is on VLAN A.
4) If you switch the security to WPA3 enterprise, the connection only workis if A = B. In any other case, the access point does not send a single RADIUS packet.
I have opened a support ticket for this same issue. I will update here if there's any change.
