jesusdf
Sep 05, 2024Aspirant
WAX220 v1.0.3.4 + Management VLAN + Radius + AP VLAN = No connection
As the title says, I could reproduce what was told in this post: https://community.netgear.com/t5/Business-Wireless/WAX220-WPA2-Enterprise-help-with-VLAN/td-p/2323906 But I have managed to fi...
- Nov 26, 2024
The proposed solution is to RMA the devices for a different (newer) model, which I accepted.
I hope that fixes it, if not, seems like OpenWRT would be the best solution for that use case.
jesusdf
Sep 09, 2024Aspirant
Hi, All the VLANs are setup as tagged on that port, so it works as a trunk. The VLAN 1 (untagged) is not used anywhere, everything has a VLAN.
ErwinL
Sep 09, 2024NETGEAR Moderator
Hello jesusdf
Looks like the port is also a member of VLAN 20. May I know which port is your DHCP server for all VLANs is connected? Is that port a member of all the VLANs on the switch? Is it coming from a router, switch or a PC? Is it tagged as well?
Have a lovely day,
Erwin
Netgear Team
- jesusdfSep 10, 2024Aspirant
Everything is connected to a pfSense firewall and a switch. The switch configuration is fine, it's a problem with the netgear firmware.
To reproduce it:
1) Management with VLAN A.
2) Wireless with VLAN B.
3) If the access point security is WPA3 personal, the connection works as expected, the users get into VLAN B, and the web administration is on VLAN A.
4) If you switch the security to WPA3 enterprise, the connection only workis if A = B. In any other case, the access point does not send a single RADIUS packet.
I have opened a support ticket for this same issue. I will update here if there's any change.
- ErwinLSep 16, 2024NETGEAR Moderator
Hello jesusdf
Thank you for reaching out to our support team for assistance. Please keep us updated on any progress with your ticket.
Have a lovely day,
Erwin
Netgear Team - ErwinLOct 02, 2024NETGEAR Moderator
Hello jesusdf
Could you please share the current status of the issue you raised with our support team?
Have a lovely day,
Erwin
Netgear Team- jesusdfOct 02, 2024Aspirant
Hi,
The support team has passed the issue to the developers and they are reviewing it.
They have agreed to tell me about the current progress this week.
Best regards,
Jesus
