jtm0n3y's avatar
jtm0n3y
Tutor
Jun 27, 2022
WAX630E AXE7800 POE Unacceptably SLOW
I have a very basic setup - 1gig coax/cable ISP service running to a FortiGate firewall, from the firewall I have an uplink with two VLANs tagged to an MS108EUP switch, from that switch I have POE++ ...
  • jtm0n3y's avatar
    Jun 28, 2022
    Putting the AP on a separate management VLAN that wasn't a part of any of the SSIDs VLANs resolved this slowness issue. No idea why it resolved it or why it caused the issue to begin with. But speeds are back to "acceptable" now.
ProSupport for Business
