twoods's avatar
twoods
Apprentice
Aug 04, 2019
Release notes for WAC510 firmware
Where are the firmware release notes for WAC510? When pressing the Release Notes link (under Management > Maintenance > Upgrade > Firmware Upgarde) it takes you to the device's support page but I can't find release notes anywhere on that page.
(Sorry for posting this under Model WAC540 but WAC510 isn't listed.)
  • twoods,
    When the WAC510 support page comes up, scroll down the page and click on "Firmware and Software Downloads."
    Then, click on the latest firmware version which is Firmware Version 8.0.6.4 and click the Download button to redirect you to the Release Notes of Firmware Version 8.0.6.4.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    twoods,
    DaneA
