pn23
Aug 27, 2021Aspirant
Same SSID on both radios using a Wireless Controller
I am using a WC7500 with WAC720 and WAC730 APs, and am unable to create the same SSID on both radios. Is this possible? Yes I am aware that this product is EOL, but this is possible using th...
- Aug 27, 2021
OK, ignore this. Being a bonehead.
It's the name of the profile not the SSID it has issues with being the same.
Problem sorted.
pn23
Problem sorted.
