AndreGr
Oct 12, 2024Aspirant
Setup two WAX625 APs as mesh network without NETGEAR Insight Cloud Portal or Insight app
I recently purchased two WAX625 APs in order to replace my current setup using Orbi RBK762S. But realized that they require NETGEAR Insight Cloud Portal or Insight app in order to setup them as Mesh ...
AndreGr
Okay, so far - decided to go with Insight subscription...
But one of the reasons I don't like remote management (additionally to privacy considerations) - is because it may simply fail like that 😫😵😡
BrianL
Oct 14, 2024NETGEAR Moderator
Hi AndreGr,
You may want to try other web browser/s and check if your network (firewall) blocks/restricts access to the NETGEAR Insight Portal.
Kind regards,
BrianL
- schumakuOct 16, 2024Guru - Experienced User
Just a curiosity question: Are you operating an all wireless infrastructure, or are these WAX625 opertated from an Ethernet switch (ideally with PoE++)?
Reson asking: On a pure wired AP infrastucture, there is -no- reason to configure this consumer-style "Mesh".
- AndreGrOct 17, 2024Aspirant
schumaku, yes, these WAX625 operated from an Ethernet switch (with PoE++, Netgear GS308EP specifically).
Agree, no need to use or activate "Mesh".
What is desired to be activated - is 802.11r (Fast Roaming), and unfortunately this feature is not available for activation without cloud management. Thus anyway, already using and configured everything with Insight app.
Thanks!
