ryan125hst's avatar
ryan125hst
Netgear Nighthawk IOT Network?
The Orbi 970 WiFi 7 Mesh Router information mentions that, in addition to a Home network and a Guest network, it has an IOT network. This router is overkill for my house and therefore I was wondering whether the Nighthawk Routers, RS700S, RS600 and the RS500, all have IOT network capabilities or are they all restricted to just Home and Guest network SSID's?
  • Due to that Smart Connect can be disabled on the NH routers, there is no separate IoT network.
  • FURRYe38's avatar
    • ryan125hst's avatar
      ryan125hst
      That's a shame as I was hoping to use Smart Connect for the main network and then have a separate IOT network on 2.4 Ghz.
