mjc775
Dec 26, 2022Luminary
Should I upgrade firmware on WAX625 - discrepancies in the release notes?
The 12/21/22 update to the WAX625 looks to have the same details as the WAX615 posted the same day. But the WAX625 previous firmware was not 10.3.1.5 - it was 10.2.6.8 (its initial release). WAX...
schumaku
Dec 27, 2022Guru - Experienced User
Which part of the list does hold you off from deploying - are you under the impression that these re fixes applicable to just one previous release?
