Peh321
Jan 28, 2024Aspirant
Slow speeds on WAX620 for 2.4Ghz
Hello, I recently purchased WAX620 and I am having problem with 2.4 Ghz speeds I am on latest firmware (V10.7.5.3) and I’m using my pixel 7 for testing. Speeds on 5Ghz are OK go around 800-900...
- Feb 01, 2024
Hi Peh321
Thank you. This means that the AP is capable of giving out the same speeds from your network. It's just the 2.4GHz network is congested in your area that's why it giving out less compared from your old AP. Maybe consider moving it to another spot or location. Or if you're okay with it already we can just simply leave it as it is.
Kind regards,
BrianL
Jan 31, 2024NETGEAR Moderator
Hi Peh321,
Can you check the speed the AP is getting from your network? Access the local UI -> Management tab -> Diagnostics -> Speed Check.
Kind regards,
Peh321
Jan 31, 2024Aspirant
Hi !
920 Mbps download
97 Mbps upload
That is what I have from my ISP
- BrianLFeb 01, 2024NETGEAR Moderator
Hi Peh321
Kind regards,
