alisystems's avatar
alisystems
Follower
Jan 13, 2021
Strange APP radio settings for WAC540
Hello guys
I have found a strange settings in the insight mobile app under Locations > WiFi > Advance Wireless Settings
In this page I can setup in radio mode the ax protocol for Wi-Fi 6!
And if I save no error is prompt.
From what I know this model does not support wifi6. Is it a feature added later or is it a problem with the mobile application?
Screen attached! Any idea?
  • schumaku's avatar
    schumaku
    This does not look like the specific AP settings. in my undertanding, these are the "max" settings for this network location.
    The controls by AP are under Location -> WiFi -> Access Points -> [whatever WAC540] -> Radio and Channels ... the UI form ooks similar, but 2.4 GHz allows setting up to 11ng, 5 GHz radios up to 11ac.
  • Advanced Wireless Settings are common for all the AP models present in the Location. If user selects 11AX mode, WiFi6 11AX mode applies only to the models supporting 11AX. For the rest of the devices which don't support 11ax, the next best mode 11ac will be applied
    • schumaku's avatar
      schumaku
      Correct. However, the App user does not have -any- indication for this, so he can only guess. There is neiter a title, a text, or a (?) which can be asked about what this "form" is intended for.
ProSupport for Business
