kenkel98
Apr 21, 2020Tutor
Unable to login after reset - AC2000/WAC124
I installed a Netgear AC2000/WAC124 for a client about a year ago. We were having issues so I reset the router. Now, I can't log back in to the router. When originally setup, I was forced to us...
- May 05, 2020
Glad to hear that it is working. You can close this thread by clicking on "Accept as solution"
Feel free to reach us if you have any questions.
Thanks,
Raghu
schumaku
Apr 21, 2020Guru - Experienced User
The only thing coming into my mind is that the WAC124 originally defaulted to an access point mode - so your observation makes perfect sense (in my simple mind as it is a wireless access point in the first priority!) - as such it won't run a DHCP server on the LAN and not issue IP addresses on the LAN ports. This default was changed from a firmware version 1.0.4.2 and above - details can be found on the WAC124 — AC2000 Dual Band 4x4 Wireless Access Point - Documentation.
As I'm not Netgear (and lack of a serial number anyway) I can't figure out under which account that WAC124 is registered - should this ever happened before.
