Vincent_Brick9
Jan 18, 2021Aspirant
Updating AP's and switches simultaniously
Hi, We have customers with several AP's as well as a switch in their network. I'm worried that if I enable scheduled updates (automatic updates) this might lead to problems with the AP's as they ...
- Jan 18, 2021
Vincent,
This comes from the Firmware tab on the Insight Web UI:
"The firmware updates within the scheduled window. During an update, the Internet access of another device may stop, which can cause its firmware update to fail. To reduce this risk, Insight updates the firmware on all edge devices (Access Points, Orbi Pro, NAS) at the same time, then updates switches, and then business routers. Review the status of all devices and manually update the firmware of any devices that were not included during the scheduled window."
Enjoy!
Vincent_Brick9
Thanks a lot! My god how did I not see this...
schumaku
Jan 18, 2021Guru - Experienced User
Vincent_Brick9 No worries - you don't know how scared I was in the early Insight times before the note was in place on automatically trigger the sites 8-) Perfectly understood your question!
