LewisArthur
Aug 07, 2024Aspirant
Can't log in to switch after firmware update
Hello,
An hour ago I updated my GS728TPv2 switch from 6.0.0.31 to 6.0.10.22. The switch has come back online, it can be pinged and anything connected as the correct connection however I can no longer log into the admin page for it.
When I enter the password and click 'Go' nothing happens at all, I don't even get an error or a red bit of text saying password incorrect, login failed etc.
Any ideas?
Try a different PC or web browser.
Clear out all web browser caches before entering the switches web page.Try a factory reset and setup from scratch...
- LewisArthurAspirant
Hello,
Thanks for your response. I have tried everything other than the factory reset with no luck.
I won't be able to try and reset the switch until Monday but I will take this as a solution and reopen the post if I have further issues.
