Moussa854AspirantNov 19, 2018SolvedURL filtering Can I increase the number of URL filtering to more than 10? schumaku to Moussa854Nov 21, 2018Moussa854 wrote: The two WAN Interface DNS entries are grayed as this is a dynamic interface type. That's why it can't work - RaghuHR the WAC510 UI needs to be enhanced so the admin can define his own DNS server IP addresses please!
schumakuGuru - Experienced User to RaghuHRNov 20, 2018RaghuHR wrote: Moussa854 Currently you can add up to 10 entries maximum. When can you remove the (honestly: useless) feature? It's just adding overhead to the code, slowing down proessing. Zero added value for security.
Related ContentFiltrage URLReadyNAS 31600 HCL (Hardware Compatibility List). exact URL?Full URLsFirmware update URL?Netgear Armor URL exclusions or whitelisting
NETGEAR Academy Boost your skills with the Netgear Academy - Get trained, certified and stay ahead with the latest Netgear technology! Join Us!
ProSupport for Business Comprehensive support plans for maximum network uptime and business peace of mind. Learn More
