penridge
Sep 03, 2022Follower
WAC 104
Hi, we have a large house and I find that the wifi upstairs at the opposite end to the incoming router is often weak. I have run an ethernet cable from my TT router into a switch / hub upstairs and n...
Sep 03, 2022Guru - Experienced User
Sure sounds like it should work.
Just make sure to install it in access point mode (it has a router mode).
And when you set it up, put it on different wifi channels from the main router to prevent interference.
