coaster13's avatar
coaster13
Initiate
Mar 28, 2021
wac 124 constantly logs you out of settings
I have a WAC124 and everytime I log into the settings,  it logs me off in less than a minute. I can barely change any settings before it logs me off and I have to log back in. This is very annoying. Please help.
WAC124
Firmware Version V1.0.4.6
Windows 10
Chrome, Edge and Opera browsers tested.
Serial Number 62Axxxxxxxxx
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    coaster13,
    Are able to access the web-GUI and login just fine before?
    Are you trying to access the web-GUI via a hardwired connection to the WAC124 or via wireless connection?
    Is your WAC124 set to Router Mode or AP Mode?
    Have you tried to turn off/on your WAC124?  If not yet, kindly try it turn off/on then check if you will be able to access the web-GUI then navigate through it without logging you out in less than a minute.
    DaneA
    NETGEAR Community Team
    • focaldepth's avatar
      focaldepth
      Initiate
      I agree with the OP, the login time out is far too short for all but the most trivial setup needs.
ProSupport for Business
