sooner
Jul 13, 2017Aspirant
WAC104 Access Point - Cannot log in
I cannot log into the IP address in order to set up security. The Wifi is working but it is unsecured. I tried using the default IP address and I did a couple of resets to the AP. I cannot see the AP...
- Jul 17, 2017
I figured it out. Here is the article that was most helpful:https://kb.netgear.com/24198/Connecting-a-NETGEAR-Access-Point-to-your-network
Thank-you.
RaghuHR
Jul 14, 2017NETGEAR Expert
Hi Charles
Can you please let us know the firmware version that you running on WAC104?
Please refer this KB article which will help you
https://kb.netgear.com/000037248/How-do-I-install-my-WAC104-access-point
https://kb.netgear.com/000038705/WAC104-Firmware-Version-1-0-4-8
Let us know your feedback
Thanks
Raghu
sooner
Jul 16, 2017Aspirant
I was able to set my PC to a static IP address and then I could log into the AP. The firmware was current. I then set the security. However, I could not log into WIFI until I reset my PC back to a non-static IP address. So I accomplished what I needed to do but still not convinced it is working as it should?
- RaghuHRJul 17, 2017NETGEAR Expert
Hi Charles,
I'm sorry. Could you please share more details. Can not login to WIFI means are you not able to login to AP UI? What is the static IP address that you have used? Have you tried clearing browser cache?
Thanks
Raghu
- soonerJul 17, 2017Aspirant
Thank-you.
