sooner
Jul 13, 2017Aspirant
WAC104 Access Point - Cannot log in
I cannot log into the IP address in order to set up security. The Wifi is working but it is unsecured. I tried using the default IP address and I did a couple of resets to the AP. I cannot see the AP...
- Jul 17, 2017
I figured it out. Here is the article that was most helpful:https://kb.netgear.com/24198/Connecting-a-NETGEAR-Access-Point-to-your-network
Thank-you.
RaghuHR
Jul 17, 2017NETGEAR Expert
Hi Charles,
I'm sorry. Could you please share more details. Can not login to WIFI means are you not able to login to AP UI? What is the static IP address that you have used? Have you tried clearing browser cache?
Thanks
Raghu
sooner
Jul 17, 2017Aspirant
Thank-you.
