Benj1
Jan 07, 2020Tutor
WAC104 not running in bridge mode
Basically, i bought a WAC104 (V1.0.4.12) to improve the current WiFi situation at home. I was told that I would be able to have both AP's run the same network. (They could both be "WiFiName", and you...
- Jan 16, 2020
Hi Benj1,
Welcome to our community! :)
WAC104 supports bridge mode but it should only be connected to another WAC104.
Another thing, Business Access Points is not suitable for Nighthawk routers, the best way to do this is to replace it with a home device too.
John
NETGEAR Community Team
JohnC_V
Jan 16, 2020NETGEAR Employee Retired
Hi Benj1,
John
- Benj1Jan 20, 2020TutorWell I might have missed the part where it said so in the documentation. Oh well, thanks for the answer though! :)
