Radworm
Jan 09, 2021Initiate
WAC104 setup. apologia.net asking me to reset password over and over and over again
I bought a brand new wireless access point to be used for WiFi coverage on one side of my house. I followed all the instructions in the setup. I am able to login in to the apologia.net site with us...
- Jan 30, 2021
Yes, I did.
I called customer service. I ended up getting it to work on my laptop using chrome also. I was able to use www.aplogin.net. Their software is glitchy. Once you change the password the first time, you have to logout back out. Then when you log back back in the second time you use the username admin and password is your newly created password (not password any longer). I was able to login back in with no issues. I was then able to access the ssid settings, change the network password, set up the time zone, etc.
If you don't log back out after changing the password the first time, it will keep asking you to change it over and over and over.
Hopefully someone will find this useful.
Thanks
Brian
JustMandy
Jan 30, 2021Initiate
Hi Radworm did you manage to solve this issue?
I had exactly the same and it drove me crackers!
In the end I solved it by using the desktop PC, accessing the access point via the IP address from Chrome. This time the password change took.
- RadwormJan 30, 2021Initiate
Yes, I did.
Thanks
Brian
