fxv300
Apr 22, 2021Aspirant
WAC124 AC200 setup as WAP
Hi, just got a WAC124 AC200 and set it up, all working fine. One of the pages in the advanced setup "LAN Setup" when selected gives some info which disappears and you are left with a blank screen...
schumaku
Apr 22, 2021Guru - Experienced User
Just the ubiquitous suggestion to drop the browser cache, especially if you just had used the Web UI on the factory firmware before the update to the current one.
- fxv300Apr 22, 2021Aspirant
Cleared cache did not work (chrome), also tried in a different browser (Edge), same result.
