network-wonk's avatar
Feb 11, 2022
WAC124 access point, Europe area, no channel 1 @ 2.4 GHz
As subject really ... I have three of these access points to provide good coverage over my house, garden and worksop. The placements that I have used give me good signal streangth in all the areas I want which is good :)
Unfortunately the channel selection dialogue for 2.4GH only lists channels 3 -> 11. The standard way of setting up three access points is to use channels 1, 6 and 11 to remove x-channel interference ... but I don't have a channel 1 :( Channel 1 is legal to use in Europe, so why can't I select it ?
Aybody know why, or any workarounds ?
-- NW
  • plemans's avatar
    Feb 11, 2022
    I don't have that device to test with or I'd try myself. (plus ours get region locked) Just makes me curious if its a EU thing with the 20/40hz wide option since it works fine when set to the NA region.
    If you set your 2.4ghz speeds for "up to 145mbps" it should drop it to 20hz wide. The up to 300mbps is the 40hz wide.
  • plemans's avatar
    All of them give you the same problem?
    What does it show when you go to change the channels?
    What region is it set in?
    What firmware is on the AP's?
    • network-wonk's avatar
      network-wonk
      Guide
      All three were flashed to 1.0.4.7, the latest listed on the Netgear web site. I think that the problem was exactly the same under the firmware that the units came with which was 1.0.4.4.
      All three behave *exactly* the same
      Region set to Europe
      As I said, when I try to set a channel, I see a drop down dialog, which lists 'Auto', then channel numbers 3 -> 11
      If I set the Region to US, I get a different set of channels I can use, which include 1 -> 11 on 2.4 GHz, but with a much reduced set for 5 GHz. After the trial I set the Region back to Europe.
        network-wonk
        Guide
        The Advanced Wireless settings page does not have an explicit channel with setting, but does have a checkbox labeled 'Enable 20/40 MHz co-existence'. The checkbox is enabled. This is the default.
        -- NW
  • plemans's avatar
    Also, do you have your channels set at 40hz wide? 20? or 20/40 mix?
ProSupport for Business
