Emmanuel_LJH
Dec 29, 2023Follower
WAC124 Disconnected when Sync with NTP Server - SOLUTION !
Hi everyone,
I had the exact same issue as this topic : "WAC124 Disconnected when Sync with NTP Server - SECOND :D"
During many months, I also tried everything to solve this problem : update firmware, change the configuration, adjust the NTP settings, ...
I was about to replace the WAC 124 for a new unit when I discovered that an open-source firmware, called "openWRT", is available for it. I gave it a try. It took me 15 minutes to install the release 23.05.0, and then ...
It works ! Yes, no more disconnection !
The WiFi range also seems to be improved.
The WAC124's hardware plateform is really great. It was just a software issue.
This little gateway is really powerfull, much more than I expected.
Disclaimer : "openWRT" is not an official firmware. It may damage your WAC124. You must carefully read the documentation. The web interface is a little bit more complicated, with much more options. A good technical skill is required.
Hope this help
Emmanuel (FR)
1 Reply
Amazing this WAC124 bug is still not addressed accordingly Emmanuel_LJH ...
