ajuk02
Jun 25, 2022Aspirant
WAC124 freezes up and requires reboot
Hello All, I have a WAC124 access point which has worked perfectly for over a year. Suddenly the AP stops working and both wired and wireless connections drop. The only fix is to reboot it. ...
michaelkenward
Jun 26, 2022Guru - Experienced User
ajuk02 wrote:
Hello All,
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
The WAC124 is a.sightly freaky "WirelessAccessPoint/Router". (Are you using it as an AP or a router?)
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
That's where most of the discussion about this device happens.
Or there is also here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Jan 17, 2024Retired_Member
