Sendermen
Mar 05, 2025Aspirant
WAC124 Locked out
All of a sudden, I'm locked out of my WAC-124. The email address I always logged in with is not 'registred' for my device. The device has been running smoothly for about 4 years. The same happened wi...
Sendermen
After doing the full reset, I could not get in. But then I saw a message about a firmware update.
WAC124 B
Firmware Version V1.0.4.9
A new version has been found. Do You want to upgrade to the new version now?
Current Version V1.0.4.6
New Firmware Version V1.0.4.9
Current GUI Language Version V1.0.4.6
New GUI Language Version V1.0.4.8
Release Notes
Fix CBUWAC124-545 PSV-2022-0096-[Mapped from PSV-2021-0338] Nightawk routers Stack Overflow and Arbitrary Code Execution - NETGEAR JIRA
Fix CBUWAC124-496 Unable to login to WAC124 from Google chrome browser
Fix CBUWAC124-537 [Security]-PSV-2022-0027-[Mapped from PSV-2022-0001] DoS in Netgear R6020
Fix CBUWAC124-543 local Password recovery is broken
Fix CBUWAC124-544 Fails to launch WAC124 with "routerlogin.net" in router mode
Fix CBUWAC124-516 CFD-Customer would like to be able to log into and manage the AP with a local admin account and not use Netgear SSO
Fix CBUWAC124-542 Day zero page Url has sso.html should be changed to default.html
Fix CBUWAC124-498 Memcpy-based stack overflow vulnerabilities
Fix CBUWAC124-541 [Security]-PSV-2022-0072-Infinite loop in BN_mod_sqrt() | OpenSSL vuln etc.
Now it only asks for a local login.
Mar 05, 2025Guru - Experienced User
If you factory reset, then you should be able to access the units web page unit default log in. Check the user manual or quick installation guide on how to set up the unit from a fresh factory reset. Should be able to use a ethernet connected PC and web browser pointed to an IP address for the unit.
- SendermenMar 05, 2025AspirantPerformed a full factory reset, everything was working fine, but now my devices fail to connect to the router.
- SendermenMar 06, 2025AspirantI changed the static IP, the device became functional again. A while later it stopped functioning correctly.
This might be my last NETGEAR product. - FURRYe38Mar 06, 2025Guru - Experienced User
The WAC is 2019 era and is EoL:
https://www.netgear.com/support/product/wac124/#download
Make sure FW is up to date.
Maybe faulty. Might try it at a different location.
Good Luck.
