W4NMH-2
Aug 02, 2023Aspirant
WAC510 Firmware Version 9.9.0.10 "Firmware Upgrade server not reachable."
Upgrading to WAC510 Firmware Version 9.9.0.10 from WAC510 Firmware Version 9.0.8.6 causes "Firmware Upgrade server not reachable."
michaelkenward
Aug 03, 2023Guru - Experienced User
How are you going about it? Manual update is the most reliable.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Check the section in the manual
Manually Download Firmware and Upgrade the Access Point
For more advice on your device, try the appropriate section:
Business Wireless - NETGEAR Communities
W4NMH
Sep 06, 2023Aspirant
Resolved, just installed F/W Version 9.9.1.3 Released on 9/4/2023
Was not a F/W Failure, but the Upgrade Server was just not available. It is now.
https://kb.netgear.com/000065799/WAC505-WAC510-Firmware-Version-9-9-1-3
New Features and Enhancements:
- Improved client notification alerts.
Bug Fixes:
- Fixes an issue where sometimes Insight throws a “Validation failed” message for a freshly onboarded AP.
- Fixes various issues in the External Captive Portal feature.
- Fixes an issue where clients connected to a captive portal SSID might not see the splash page for authentication when the VLAN of the SSID is the same as the AP management VLAN.
- Fixes an issue where AP starts operating on 802.3af power even when powered with an 802.3at or 802.3bt switch.
- Fixes an issue where the captive portal splash page is not displayed when a client connects to an SSID using WPA2 Enterprise security.
- Fixes an issue where active user sessions are not logged out when location-wide device credentials change.
- Fixes an issue when Syslog configuration disabled by the user get enabled again after AP reboot.
- Adds system stability improvements.
