Nana11's avatar
Nana11
Tutor
Nov 07, 2020
WAC510 firmware version 9 cannot use tagged VLAN.
I use WAC510 in local web management, with tagged VLANs to use multiple networks.   However, the WAC510 firmware version 9, all devices cannot access the network normally in VLANs other than the m...
  • Nana11's avatar
    Nana11
    Nov 14, 2020
    I was able to successfully self-solve this problem.
    I updated the WAC510's firmware to the latest, did a factory reset and reconfigured everything from the initial settings, but still had the same problem.
    Maybe, but it seemed that some people were using the same WAC510 and didn't have the same problem, so I next checked the operation, changing each setting one by one.
    After doing so, I discovered what was causing the problem.
    The problem was located under Management>Configration>Wireless>Basic>WLAN Settings.
    I found that if the Wireless Client Isolation in the Advanced SSID setting was enabled, I couldn't communicate with any non-Wireless addresses too.
    By disabling this setting, I was able to have network access on any VLAN other than the management VLAN.
    I suspect that the point about not being able to communicate with non-wireless clients and gateways is a bug.
    I'll be using this setting disabled until this issue is fixed.
