russc155's avatar
russc155
WAG102 & WG102 Wireless not connecting
Hi,   I'm not sure if this is the correct place to be posting so I appologise if it is wrong.   I have 3 Netgear WAG102 Access points and 2 WG102's. I believe I am setting them up correctly and a...
  • JohnRo's avatar
    JohnRo
    Sep 13, 2016
    Hi russc155,
    If you have tried my suggestions and still experience the same issue, I suggest contacting our Support Team. They will be of great help in isolating the issues you are encountering.
    Thanks,
ProSupport for Business
