russc155
Sep 09, 2016Aspirant
WAG102 & WG102 Wireless not connecting
Hi, I'm not sure if this is the correct place to be posting so I appologise if it is wrong. I have 3 Netgear WAG102 Access points and 2 WG102's. I believe I am setting them up correctly and a...
- Sep 13, 2016
Hi russc155,
If you have tried my suggestions and still experience the same issue, I suggest contacting our Support Team. They will be of great help in isolating the issues you are encountering.
Thanks,
JohnRo
Sep 12, 2016NETGEAR Employee Retired
Hi russc155,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
russc155
Sep 13, 2016Aspirant
Hi,
Sorry for the late response I was just trying a few more options before responding. Sadly this issue still seems to exist :(
Thanks
- JohnRoSep 13, 2016NETGEAR Employee Retired
Hi russc155,
Thanks,
