papajh
May 04, 2025Follower
WAX 214 AP
I have 9 WAX 214 access points in my home. Upon installation, each AP was renamed. Each has a unique login password. However, all were set up to broadcast the same SSID using the same WiFi passwor...
May 05, 2025Guru - Experienced User
Log into the router managing them and check the IP addresses for them. it might take a little searching to find a specific device.
