papajh
May 04, 2025Follower
WAX 214 AP
I have 9 WAX 214 access points in my home. Upon installation, each AP was renamed. Each has a unique login password. However, all were set up to broadcast the same SSID using the same WiFi passwor...
waseem485
May 14, 2025Aspirant
To access each WAX214 individually, you'll need to log in using each unit's unique IP address rather than 192.168.1.1. Check your router's DHCP client list to find the IPs assigned to each AP, then enter those directly in your browser to manage them one by one.
