Peter30457
Dec 09, 2024Aspirant
WAX 615 has trouble starting up
Have just fired up my new wax615 access point. I cannot log in and it is not acting as a useable wifi. Unfortunately all I am getting is a series of flashing lights. The power/cloud button cycles thr...
RennaD
Dec 10, 2024NETGEAR Moderator
Hi Peter30457,
If the Power/Cloud LED is blinking amber slowly, continuously, then it means that it is unable to get an IP address from the DHCP server. What is the make and model of the router that you are using? Can you try to connect a computer on that same port where the AP is connected and check if it is able to get IP address and internet access?
Also, for additional information on the LED status and possible troubleshooting steps, please see page 233 of the link below:
https://www.downloads.netgear.com/files/GDC/WAX615/WAX615_UM_EN.pdf
Have a lovely day,
RennaD
Netgear Team
Peter30457
Dec 11, 2024Aspirant
Thanks for your reply.I did as you suggested and connected my iMac straight to the router via ethernet and it seemed to work fine. The router is a Deutche Telecom Speedport Smart 4. It is not that old. I have looked right though the GUI and cannot see anything that helps with DHCP. Thoughts.....
- PramendraDec 11, 2024NETGEAR Expert
Hi Peter30457
>>> The power/cloud button cycles through blue, green and amberBased on the LED status in your first email, it appears that the AP is acting as an extender and looking for a root to form a mesh network.
If this is unintended, the AP might be unable to reach the internet and gateway, possibly due to not getting an IP from the router or a loose/faulty cable.
I suggest factory resetting the AP by pressing the reset pin for at least 10 seconds and then releasing it. After this, check if you can see the default SSID (NETGEARXXXXX_SETUP). If yes, the AP is good to go.
Thanks!Pramendra
NETGEAR NFB Wireless Team
- RennaDDec 16, 2024NETGEAR Moderator
Hi Peter30457,
We’d greatly appreciate hearing your feedback letting us know if the information provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Have a lovely day,
RennaD
Netgear Team
